2005 Taurus cranks but won’t start
Intermittent problem. Starter cranks, freewheeling without fire. Completely unpredictable. Once started all is fine. No cel, battery great, replaced camshaft position sensor, replaced starter
sounds like a compression problem take it to a mechanic have them do a compression test and leak down test if leak down fails our compression fails youll have to get either a used engine or have it rebuilt
这个答案有帮助吗?
I got 98 Taurus it no crank no start I replaced mass air flow make sure battery disconnect cause I didn't so after I changed it I started car it started leave car running don't shut off because I did and the car won't start at all so I got to reset pcm before it start so to reset it get a resister cost about dollar fifty parts store all need is 10amp-1ome connect the the end wires to battery terminal disconnect from battery so just terminal then leave connected like ten fifteen minits it will reset pcm coad
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 392
