跳转到主内容
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
134 个问题 查看全部
Micro USB port is worn.
The micro USB port is worn or bent, such that it will only charge if the cable is held at just the right angle. And data transfer is out of the question! Is this a simple fix, or would I need to change out the whole motherboard?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Watts Isnaim if your Samsung is indeed a Samsung Galaxy Tab 4 7.0 you will need to remove the motherboard. The charging port is soldered into the motherboard. Not an easy task but if you know how to do some decent soldering you can probably do it. Use this guide Samsung Galaxy Tab 4 7.0 Motherboard Replacement to remove the board and use something like this video to see how it is being done. Replacement ports are available at places like this and many others.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Watts Isnaim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 49
