2.26 or 2.4 GHz / White plastic unibody enclosure
678 个问题 查看全部
Spilt water on MacBook, but cannot remove battery
I spilt some water which has gone inside the computer. I stupidly tried swithching it on before allowing to dry. It came on shortly and then went off. I have removed the back cover and want to remove the battery as recommended in other solutions. I cannot do this however as I do not have a tri-wing screwdriver.
1 Is it really essential for me to remove the battery?
2 Is there a way to remove the battery without a tri-wing screwdriver?
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
I have managed to remove the battery. Should I leave the bottom cover off while the computer dries?
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
最有帮助的答案
A screwdriver from Radio Shack is a lot cheaper than a logic board replacement.
这个答案有帮助吗?
按维修分数 2
评论:
Unfortunately I live in Zimbabwe and its 9p.m at the moment.
Ouch! Now is the time to improvise a tri-wing somehow. You do need to remove the battery. Good luck.
What, no Radio Shack in Zimbabwe, what's the world coming to? ;-)
Got the battery out with a flat head screwdriver
Here's the guide on water damage: Electronics Water Damage
添加一条评论
添加你的答案
Wilson Luke 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 2,891
