跳转到主内容
Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
Top screen has lines and is faded
My XL was dropped and now the top screen is really faded and has lines on half the screen. Bottom screen works fine and sound does too. Only problem is the top screen. Took it apart but what do I need to look out for?
Thanks
Michelle
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
6个答案
最有帮助的答案
Here is the Guide and the part is available here and many other places As for hard to replace, it does depend on your skills and comfort level.
Replace a damaged or malfunctioning 4.2" 256 x 192 Upper LCD panel compatible with the Nintendo DSi XL portable gaming console.图片
产品
Nintendo DSi XL Upper LCD
$84.99
这个答案有帮助吗?
得分 2
添加一条评论
You cannot really fix this problem, the only thing that you can do is replace the top screen. If it was dropped the screen was probably smashed (inside LCD) and there is nothing you can do other than replace it.
Sorry for the inconvenience.
这个答案有帮助吗?
得分 0
1条评论:
Would it be hard to replace? And would it be cheaper to send it Nintendo to fix? They charge me $80 to fix.
完成的
添加一条评论
The top LCD is not a great DIY project unless you're used to handling small ribbon cables. If you aren't careful, you'll tear the new ribbon as you're installing it. New LCDs are $10-$20 on ebay. Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
i have the same problem!!!!! don't want to send on it in or replace
这个答案有帮助吗?
得分 0
2条评论:
jala mcfadden, what problem do you have with your DSi and what did you try to fix it?
完成的
jala the only place you can put your contact information id in your profile.
完成的
添加一条评论
Yeah one day i decided i wanted to play on my Dsi XL and I struggled to pick it up from my desk and when i finally got it i opened it and the top screen was like halfway blacked out and random color lines were on it too i have know idea how to fix it plus its not even mine
这个答案有帮助吗?
得分 0
添加一条评论
have heard that the ribbons can be replaced but it needs specialized equipment like Z axis tape (this is for the lines only/blank problem, and a subset of those) but the glass is normally the cause.
I have a very expensive camera here with this fault, internal cable went bad but its a special sort of tape more expensive than standard Z axis as used in ipad repairs, chibitronics kits etc.
This works fine if the alignment is spot on for relatively large pitch connectors however like calculator panels!
If you have a good ribbon and screen then try https://www.adafruit.com/product/1656 might do the trick but alignment needs to be finer than a human hair.
Best done under a microscope or better still screen+camera.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michelle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 28
总计 8,873
