跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Repair guides and support information for televisions manufactured by RCA.
108 个问题 查看全部
T-con for RCA sld65a55rq not matching
I need a t-con board for an rca sld65a55rq but the boards I’m finding by the tv model number do not look like mine. The pics of mine are below. I found some using the board number but the printed number to the right isn’t the same and I don’t know what that one means (1440 on the pic). Does anyone know if that matters, or could point me towards the correct board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
Manta 螺丝刀工具包
日常维修的112个替换头
Upgrade Your Toolbox
Manta 螺丝刀工具包
1个回答
Hi,
Not totally sure but going off the sticker number 5565T07C19 there is this board which also mentions your model number as well as another model.
You could try contacting this supplier and confirm whether the ‘green board” (bottom of the page - out of stock I know) would be suitable for your model. It also shows the same “other” TV model number that the board is used for.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kamakookie 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 11
