跳转到主内容
PlayStation Vita(PSV)是PSP的后续机型。PSV具有更加强大的处理器与画面,添加了第二个类比摇杆。PSV发售于2012年2月15日。
165 个问题 查看全部
PS Vita 1000 - Cable charging the console, but not transferring data!
Hi!
I have this problem where i ps vita data/charging cable was damaged but i continued using it. One day it Short-circuited and now i cant transfer file from my PC to Vita or vice versa. i can only charge it! Charging works fine.
Its not the cable, i tried other working cables, its the vita it self.
How can i fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @sonicboi ,
You can check the pins in the port with a multimeter for continuity. Maybe the data lines got damaged.
Other way is to hack your console and use VitaShell which is a file manager that allows you to transfer data via FTP protocol. But this is rather a workaround than a fix.
这个答案有帮助吗?
得分 0
2条评论:
I hacked my Vita and use WiFi, that's why i want to fix USB data because its broken and WiFi is not so fast and convenient.
I was hoping for some help on actual fixing, schematics of VITA, what to do, where to touch and where not to touch etc.
完成的
Bro... Did you manage to fix it? Have you try to see the pins at the charging port? Any burnt pin?
完成的
添加一条评论
添加你的答案
Sonic Boi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 798
