跳转到主内容
A collection of guides and support to help with washer repair.
2792 个问题 查看全部
GTWN4250D1WS ticking noise coming from top of motor inverter board
GE washer top load does not agitate or spin.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
So first off there is no good answer that you would want to here as the fix is having to order replacement motor which cost is around (see below). The concern is the ticking noise is transistor on heat sink is discharging to motor case bolt. There is nothing wrong with the motor just the motor inverter board (under steel plate mounted on top of motor) which is not sold by itself. Replacement board is not available anywhere and could be repaired if you could diagnose failed components. Motor replacement is your only option unless there is a company that can repair the boards.
Hopefully this could answer the question.
Drive Motor
Genuine OEM Part #: WH20X10094
Repairclinic Item #: 3029967
Quantity: 1
Price: $202.23
Item Total: $202.23
这个答案有帮助吗?
得分 0
添加一条评论
REF: https://f01.justanswer.com/smitty1486/74...
The above link is a mini-service bulletin for your washer.
Before replacing the motor/inverter assembly, you want to check for error codes. First, go to page 2 of the service bulletin above and perform item 7 to check the motor status. Count the number of inverter status light flashes and refer to page 1 to decode the error.
Besides the motor/inverter assembly, other possible issues are the lid switch, the drive belt , or the mode shifter. The error codes should help point you in the right direction.
If the motor is reporting a normal status, perform field service mode on page 1 for other troubleshooting.
这个答案有帮助吗?
得分 0
评论:
And yes I agree with you but that was not the case as the code was 3 and to replace inverter board thus motor replacement
完成的
Yeah, an error code of 3 requires a whole new assembly. Sorry. Hopefully, my answer can help someone having a similar problem.
完成的
添加一条评论
添加你的答案
DM 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 4
总计 172
