Charging but dead logic.
Hi. I’m trying to fix my macbook pro logic board. It suddenly shutdown and wont turn on after that. Can i know what it is on picture above?
Update (02/03/2020)
Already change the capasitor..
To attempt a spontaneous reboot, dis connect the mag-safe and battery. Press and hold the power button for 10 seconds. Reconnect the battery then connect the mag-safe adapter. If your logic board is good it should reboot on its own.
这个答案有帮助吗?
It does look like the capacitor blew
Here’s a better view
C6603 100UF 20% 6.3V Tantalum Case-AL1
And lastly here’s a view from the boardview
Double check that the other components are OK by cleaning the area with 85% isopropyl alcohol if the cap is the only component thats damaged you’ll need to get it replaced.
这个答案有帮助吗?
Sorry for late reply..thanks for the answer..already change the capasitor..tq very much for the boardview.really appriciate it.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 99
3条评论
Can you tell us your exact model. Plug in your systems S/N here EveryMac - Lookup and tell us what you got.
由 Dan 完成的
What's the matter @danj can't you read fine print sideways?
Apple MacBook Pro 13-Inch "Core i5" 2.4 Late 2011 Specs
Identifiers: Late 2011 13" - MD313LL/A - MacBookPro8,1 - A1278 - 2555*
co2gx870dv13
由 mayer 完成的
@mayer - Ha!! ;-}
I had only looked at the second image!
由 Dan 完成的
