跳转到主内容
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597 个问题 查看全部
MacBook Pro with question mark folder but disk doesn't appear on OS in
Hi,
My macbook pro starts with the question mark folder. I then used the disk utility (after getting Internet Recovery sign) to repair the disk and it seems okay but when I try to install the OS it doesn't detect any disk and only the Mountain Lion OS option that appears while my mac OS was updated last year. I read somewhere that it may be the cable or the disk is faulty. I am just confused because I can see the disk in the disk utility but can't see it on the OS installation and start up disk. Should I bring my laptop to apple center or can I fix it myself? Because to be honest I'm kind of broke now :(
Thank you in advance for your help!
Linda
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Apple did a switch-a-roo on you! The older OS-X & macOS Sierra and older use GUID/HFS+ (also known as the journaled file system) High Sierra and newer uses GUID/APFS!
So what can happen is the recovery partition OS still has the older boot image and access to the older Disk Utility which can’t handle the newer APFS structure, which is what happening here.
So now we have problem! How do we install the newer OS when your system recovery partition or Internet recovery only gets you to Mountain Lion! This gets into the keys you press to enter into the Internet Recovery. Here we need to use the startup keys Command (⌘) and R. This will re-install the same version you had before. Give that a try!
Reference: How to reinstall macOS from macOS Recovery
这个答案有帮助吗?
得分 1
添加一条评论
Try reformatting the drive to GUID partition
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Floresia Printables 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 138
