跳转到主内容
发布于2017年6月,iPad Pro 10.5寸替代发布于2016年的iPad Pro 9.7寸。
145 个问题 查看全部
Ipad pro 10.5" shuts down after 10 min charging.
Hello my fellow fixers and heroes.
I'm interested in a faulty iPad 10.5” on auction which has the fault described in title. It shuts down by it self and after 10min of charging, it shuts down again.
The seller had it looked up. And they told him/her that it was something with the “power supply chip". Which I translate to charge board flex cable? I don't know.
Therefore my question.
Do any of you know if it's repairable? Would it be worth it? And what is the actual damage?
Thank you!
~May the patience be with you~
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Charge related issues could be the charge port, the battery or the charge circuit on the logic board. The charge circuit could be damaged by some water ingress, poor quality chargers or cables or just random component failures. There’s no way to know without opening up the device. If there’s water damage, I wouldn’t touch this device.
Otherwise, calculate that you will have to lay down $150, maybe more to have this repaired and there’s always a possibility it is unrepairable. Besides, the original owner didn’t get it repaired and if they had, they could sell the device for more so I’m always wary of buying devices that are damaged. If you buy it, you have to accept the risk that you will lose everything (minus whatever buyer protection you have, i.e. eBay).
这个答案有帮助吗?
得分 2
3条评论:
Thank you for taking the time to answer!
I've talked to the seller and as I've said before, It's the "chip supply" or "power providing chip". Don't really know how to translate it. But basicly sounds like it's the"lightning connector" that needs to be repaired or replaced. It wasn't a water damage, he had it for inspection at a dealer, that provided him this solution.
But, I don't know if the "chip supply" and " lightning connector" is the same thing. If it is, I guess it needs soldering?
完成的
"chip supply" or "power providing chip" are totally different from the Lightning connector. Replacing a flex is relatively straightforward, logic board issues, especially if it turns out to be the PMIC, are quite another.
IMHO, I would not buy this, worst case have the seller fix it first and you pay for the repair on top of the purchase. Otherwise you may end up with a device that is not fixable.
完成的
Okey,
I understand the issue. Thank you for clarifying it.
完成的
添加一条评论
添加你的答案
Pontus Sennerstam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 184
