Sanyo tv has lost all channels and won't auto or manual tune
I have a Sanyo LED-42XR10FH which has suddenly lost all channels and won't auto tune or manual tune. Powers on fine, other devices connected work, just no channels. I have tried disconnecting from wall, factory resetting, checked all cords, replaced coaxial but continue to get a no signal message when trying to manual tune. Old tv but has worked perfectly until now.
4条评论
All I have is an antenna hooked up to my TV I cannot get any picture when I go into menu I cannot find where to auto scan to add channels to my TV please help
由 Elklady 完成的
@Elklady
What is the model number of the TV? This information is usually found on a label at the back of the TV
usually to set up the TV you look in Menu > Setup.
If you had the TV connected to a cable box before you may have to change a setting from "cable" to "antenna". It should be located inthe Setup area of the menus but maybe not.
The model number is needed to help you further.
由 jayeff 完成的
How do I get channels back if TV wont program them?
由 tabbaphil 完成的
Hi @tabbaphil
Check the comment above yours here and see if that helps
由 jayeff 完成的
