跳转到主内容
Nintendo DS 的后继机种 Nintendo DS Lite 于2006年发布。这款设备的拆解和维修十分简单。
My DS fell and doesn't turn on
The other day my Nintendo DS lite fell out of my hands. After that it didn't turn on anymore.
When I plug it in the charging light turns on, so the I thing it's receiving charche and battery is ok.
I took it to a place in my city and they told me to change the bottom screen although they don't have new parts and are hoping someone sells them a used one.
what should I do? I live in Mexico and don't know where to fix it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
8个答案
最有帮助的答案
Most common fault with dropped ds, a component comes off mainboard, big capacitor next to power switch.
If one of your screens is faulty, the other screen flashes quickly on then ds turns off.
这个答案有帮助吗?
得分 2
2条评论:
Actually, it's an inductor, not a capacitor, but I've seen it come off of several DS Lites. It's an easy solder for someone that works on electronics, but be careful to not loose it when you open it up as it could be rolling around loose.
完成的
Same thing happened to my DSLite, It was dropped and the big capacitor/indicator next to the power switch came clean off. The only problem is i can't get the solder to stick to the dam thing to solder it back on. does anyone know what it is so i can replace it? If its an indicator, can i just solder a link over the board?
完成的
添加一条评论
Hi Lorena. I'm sorry to hear about your DS lite. I don't understand how the bottom screen could be preventing the DS from turning on. If the bottom screen was defective, you would at least hear sound when the DS is powered. You may have damaged the logic board or some other component. But if you're looking for replacement parts, this link should help you get started. Good luck.
这个答案有帮助吗?
得分 1
添加一条评论
Unfortunately, Nintendo has a fail-safe in their DS systems to discourage hackers. If any screen is disconnected at all, then the DS won't boot up. When you turn it on, does your green light come on at all? This is very important as to what the cause is, but it's most likely just a semi-disconnected screen cable.
这个答案有帮助吗?
得分 1
添加一条评论
256fx
It Is called a L2 inductor, you cannot bridge the solder across the gap. try turning the l2 over so you have a clean piece to solder to, only use a 15/20 watt soldering iron tho. check It hasn't blown by putting a continuity tester across it. you can buy these L2/4 from ebay for about £3 or so, also check the L4 on the opposite. side of the board. They look exactly the same but have different values, make sure that is still on with no hairline cracks in solder joint.
Hope that helps
这个答案有帮助吗?
得分 1
添加一条评论
Hi, My DS also fell. It's charger works, and the light on the ds also turns on. But My ds doesnt work even if I charge it the whole day... Can anyone please help me... I've tried alot!!
这个答案有帮助吗?
得分 0
1条评论:
Have you tried what people mentioned above? It could be the inductor or a loose LCD cable.
完成的
添加一条评论
selena, if you've dropped your ds and you only get the green light, check that the wifi module is seated correctly(push it back down on the board), these sometimes pop off during a drop or bang on a table for instance and are only secured by a thin layer of double sided tape. it is the big component to the left of the game slot and has either a black or blue wire going to it.
这个答案有帮助吗?
得分 0
添加一条评论
I'm having a problem similar, but MUCH worse.
My DS Lite CAN charge (when plugged in the orange light comes on, but quickly turns off due to the battery being full), but the DS won't turn on. Like, AT ALL. No green light, no sound, no nothing, just a dead DS. Now what?
这个答案有帮助吗?
得分 0
添加一条评论
Hi everyone,
All nintendo DS consoles will not turn on if:
- One of the screen or their flat cables are broken or loose. (Do a visaul inspection)
- Fuses are in short circuit (You will need a multi-meter and check for continuity in F1/F2)
- Wifi card is not sitting correctly in place ( this is a very common issue even if the screens are ok).
There is plenty of information in the web, once you identify the issue get more details or let us know.
Good luck and good repair.
JM
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lorena 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 61
总计 19,882
