跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
244 个问题 查看全部
MacBook Pro 15 late 2016 no backlight
Hey guys,
the backlight on my laptop doesnt work. I tried pram and sms reset but nothing worked. When i put a flashlight on the display i see that he booted up and i can also plug in a external display and it works. Any ideas for what i can do? I read that maybe somethings wrong with the connectors on the logic board. The laptop was never wet and never falled down.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
最有帮助的答案
Sadly, your backlight ribbon cable has failed. This is a cable that runs between the system logic board to your display
This is a common issue on both the 13” & 15” 2016 & 17 models. Most people know it as FlexGate 2018 MacBook Pros Try to Solve Flexgate Without Admitting It Exists. Apple did create a extended warranty program for the 13” models 13-inch MacBook Pro Display Backlight Service Program. You’ll need to plead your case at an Apple Store to get a warranty exception which some people have managed to get for the 15” models. You’ll likely need to work up the food chain within Apple from the Genius, service manager, store manager(s) and then to the regional manager(s).
Your other option is to just get a new display assembly. Here’s the guide: 2016 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换
If you know of a very good micro soldiering tech the damaged cable can be replaced its not easy! Here’s the cable https://www.ifixit.com/Store/Mac/MacBook.... I failed on my first attempt!
这个答案有帮助吗?
得分 2
5条评论:
Thank you very much! I read about this flexgate issue so i will try to contact the apple store to see what they will tell me.
完成的
I would just walk in Vs calling. I often find the telephone support folks tend blame you instead of being helpful getting you an appointment which is all they should do here.
完成的
Do you know if they will replace the display with the newer one from 2018? Or will i get the same 2016 Display which can cause the same problems one year later?
完成的
You'll need to ask Apple that!
What I can tell you is Apple rev'ed the part to 661-08030 from 661-06375 for the Space Grey part and to 661-08031 to 661-06376 for the Silver so clearly something changed!
完成的
Ok thank you!
完成的
添加一条评论
I also have a 2016 15" MacBook Pro with this problem, however, the lid has been closed less than 10 times in it's lifetime so I don't think it is related to FlexGate. Could this be caused by anything other that the $750 fix?
这个答案有帮助吗?
得分 0
1条评论:
The angle of the lid plays into this so it still could be! The only way is to have someone with the deeper skills inspect the cable for damage
完成的
添加一条评论
添加你的答案
Lukeatthis 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 29
过去 30 天: 122
总计 5,672
