跳转到主内容
加入维修社区 - 创建账户
The TH (turbo-hydramatic) 700R4 was developed for use after 1982 in GMC and Chevrolet cars and trucks.
When it gets warm it shifts too fast.
When the transmission gets up to temperature it shifts through the gears too fast.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi @rhoyer
Have you checked that the level of the transmission fluid is correct?
Does the fluid smell like it is burnt?
完成的
Fluid level is fine. Didn’t notice any unusual smell.
完成的
添加一条评论
1个答案
incorrect fluid levels or leaks, try replacing the fluid or inspect for any leaks or misting, worn or damaged parts inside the gearbox could also cause it. depending on age, mileage and how the cars driven may need inspecting inside.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 268
