第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
3267 个问题 查看全部
Help ID a pie-shaped leftover part from a GSM iPhone 4 repair?
Hi there:
Recently replaced the screen in my iPhone 4. Everything works great, but I was left with one leftover part that I've been unable to place.
It's a flat, pie-shaped piece of metal, about 0.5cm at its widest point, with a hole in it.
Anyone have any ideas? I've reviewed the other reports of leftover parts and this one doesn't seem to match any of the ones I've seen.
A link to a picture of the part:
http://tinypic.com/view.php?pic=2crodon&...
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
5个回答
已选择的解决方案
Hi. The triangular washer is a black spacer that is under the Phillips screw near the vibrator. Here's a picture of the spacer. As for the tiny foam block, are you referring to the outer plastic ring located on top of the rear camera's flash assembly?
这个答案有帮助吗?
按维修分数 2
评论:
Well I think i found the piece of foam you're talking about. If you take a look at the picture of the speaker assembly, more specifically on the lower left corner, you'll notice this rectangular foam block. It looks like a brick. Is that it?
yes walter this is the block. any idea about the pie slice metalic washer/spacer/contact?
Well I'm glad we identified at least one of the components. Unfortunately I don't recall any triangular metallic spacer in the iPhone 4 GSM. Can you take a picture of the spacer?
yes, but how do i post the photo to you. it seems to be the same size as the black piece in the Verizon model. All the photos and videos I am able to find show nothing under the 1.9 mm screw at teh bottom of the mother board under the ribbon connector bottom left. triangular with a hole slightly offset from center
added a photo, it must fit under the screw as a contact plate between the screw head and the 1/2 circle brass contact point on the MB.
显示更多的2条评论
添加一条评论
My advice, if your iPhone still works then who cares! There are small parts like this throughout the phone that don't actually do anything and are just failsafe's if something does stop working. 99% of the time they are never needed :)
这个答案有帮助吗?
按维修分数 0
添加一条评论
I too have been unable to find where this part actually comes from.
My disassembly of the iphone 4 was all going well until i had to turn the frame over to seperate the screen from the body - that's when the piece fell out. I didnt even notice it in the phone before it fell.
Has anyone worked out where and what this is used for?
这个答案有帮助吗?
按维修分数 0
添加一条评论
I think this part is located under the 1.9 mm screw holding the bottom of the Mother board down. To the left side (from back)just above the speaker assembly. I am not certain but I believe its to aid contact of the screw to the Motherboard. the pointed side goes toward the outside frame and the the narrowest side to the bottom of the phone. The screw makes contact without it, so it will still work.
这个答案有帮助吗?
按维修分数 0
添加一条评论
I've just found the exact same washer during re-assembly of a GSM iPhone 4. I've done dozens of these and never come across this washer before. It's not the plastic washer used near the vibrator on a 4S, this is pie shaped metal.
It was stuck to the adhesive where the battery sits but musty have become dislodged from someplace, but where??
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Patrick Kane 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 2,554
