跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2072 个问题 查看全部
front camera shows black screen
my iphone shows a black screen when i turn on my frontcam. i changed the frontcam with 3 diffrent replacements and it’s still black. the top speaker does work
can somone help me ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
已选择的解决方案
There would be one more thing you can look at and that is the connector on the logic board. Check there is no damage to the pins; you might need a magnifying glass to check properly.
Other than that it will cost you money as the next step would require a reputable repairer to check the diode readings of the connector to see if there are any open or shorted lines plus check to see if it is getting power. This is not easy as you need the connectors connected and the camera app open.
这个答案有帮助吗?
得分 2
添加一条评论
If such is the case I would recommend this:
If you launch the camera app [SPAM deleted], and see a black screen that doesn’t change, try the following:
  1. First, make sure that nothing is actually blocking the camera lens. You may have put a case on incorrectly, or there may be something stuck to the camera hole.
  2. Close the camera app by double-clicking the home button and swiping the app card up to kill it. On an iPhone X, swipe up from the bottom and leave your finger halfway up to bring up the app switcher, then long-press on any app preview until a red circle shows up in the top left corner. Close apps by tapping on that circle or just swipe the card up and away.
  3. Try launching the camera app again.
  4. If that didn’t work, try restarting your device and then launching the camera again.
  5. Try switching back and forth between the front and rear-facing cameras to see if the black screen appears on both. If it’s only one, you may need to take it to an Apple Store.
If you’ve tried everything above and it didn’t fix your camera problems, then you may have a hardware problem. You should try the following:
  1. Double-check that the camera lens is not obstructed by a case, sticker, or similar objects.
  2. Make sure there are no smudges, dirt, or debris on the camera lens. Smudges and fingerprints should wipe away easily with a microfiber cloth. If dirt and debris are under the glass lens, take it to an Apple Store or Authorized Service Provider.
I hope this helps!
Regards.
Judy Smith
这个答案有帮助吗?
得分 1
评论:
thank you for your answer. but i did all those steps before i replaced the frontcamera 3 times. the only step i didnt do is bring it to the apple store. an independant repairer tried and failed tho.
its not worth it to pay more than a 100 euro's to fix the phone, i would like to fix it myself but i cant find the solution.
完成的
添加一条评论
添加你的答案
henri loosveldt 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 22
过去的30天: 131
总计 2,621
