跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
Docking port corroded by water.
Water was wicked in by sitting iphone up right on wet towel cloth everyday for about a week at gym.Connection are corroded and phone will not turn on,don't no if I did further damage by shorting something out inside or do I just replace the dock?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
First things first, hopefully it isn't too late. Get the phone dry. Not just the outside, but everything inside too. This means you'll need to open the phone, and dry it out some how. A good way is to leave it in a bag of uncooked rice for about 24 hours.
After you are completely sure the phone is as dry as the Sahara desert, try turning it on again. If it still doesn't turn on, You'll need to start replacing parts. Here are the first few I would suspect:
  1. Dock Connector
  2. Battery
  3. Display Assembly
  4. Logic Board (bad news)
If it is the logic that went bad, then your best opportunity is to sell the working parts on eBay and using the money to buy a new phone.
EDIT: Don't use a hair dryer (or other heat source) to dry the phone, or you'll just ruin your phone.
iPhone 3G Battery图片
产品
iPhone 3G Battery
$14.99
iPhone 3G Display Assembly图片
产品
$59.99
iPhone 3G Dock Connector图片
产品
$9.99
这个答案有帮助吗?
得分 2
添加一条评论
You won't be able to just replace the dock, I'd say your motherboard is shot so it will need to be replaced. Even if you could replace just the dock, most likely the motherboard would be nonfunctional from water damage or shorting out.
这个答案有帮助吗?
得分 1
2条评论:
I gave you a - for jumping to conclusions... not all waterdamage kills the entire phone or is irreversible.
完成的
True.. good point. There are many times when the motherboard is salvageable, thanks for the input.
完成的
添加一条评论
添加你的答案
Anthony 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,916
