跳转到主内容
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
75 个问题 查看全部
iFixit Toolkit cannot open Dell XPS 13 9350 battery
I have bought "iFixit Pro Tech Toolkit - Electronics, Smartphone, Computer & Tablet Repair Kit" in order to change my XPS 13 9350 battery.
I successfully open the bottom case and able to open 2 screws at the right part of the battery.
But I could not open the 2 screws on the left part of the battery (please see attached file with circle in red color). I have tried all head styles of iFixit, but none can open the screws.
Appreciate any help. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
You don't seem to have uploaded an image so it's a little hard to tell, but according to the guide they should just be regular Phillips head screws. It's possible they got stripped if too much torque was applied, can you try uploading or linking an image again?
这个答案有帮助吗?
得分 1
4条评论:
Uups, sorry forgot to attach the picture, thanks for remind me.
I have used all the head screw styles, but none of it match.
完成的
It's harder to tell for the one at the top but the bottom one is definitely stripped which is why you are probably having issues with it. But it is standard Phillips.
完成的
The chassis will probably flex a bit when trying to unscrew those screws so I would say put opposite pressure under the screw under the chassis with your hand and use a PH00 / J00 or larger screw tip. Smaller ones will just cause it to strip.
完成的
@cosmasaay - Can you take a tighter picture of the top Black screw.
It looks like a tri-point, you will likely need a Y0 or Y1 bit
完成的
添加一条评论
The guide in step #7 is showing this as a small Phillips:
Dell XPS 13 电池更换
But if it id really stuck you may have to use extractor pliers.
Screw Extracting Pliers
Screw Extracting Pliers图片
产品
$19.99
这个答案有帮助吗?
得分 1
1条评论:
these screws are FIRMLY Locktited in there. I can't break them loose. How do I release the Locktite?
完成的
添加一条评论
添加你的答案
Cosmas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 559
