Power Issues After Spark.
Hi, I am having some issues with the battery and charging on my MacBook Pro. Recently I noticed a spark from the MagSafe port when I connected the charger. Not long after the battery low warning started flashing repeatedly in a way it has never done before. It was as if the charger was being connected and disconnected repeatedly.
I thought the battery was at fault so purchased a OEM replacement but this has not fixed my issue.
My MacBook works perfectly normally except from the fact I can no longer charge the battery. The battery status says Battery Not Charging and Power Source: Power Adapter but the power adapter is not connected and it has no affect when it is. When I do connect I get a very dim green light.
I have tried the SMC reset and NVRAM/PRAM reset but again it has not helped. I am starting to think that perhaps the charging port was damaged and a replacement would solve my issues.
Any help would be appreciated.
thanks
