跳转到主内容
Released August, 2013. Identified by model number NP270E5E-K03US.
3 个问题 查看全部
My Samsung NP270E5U-K03NG don't want to power on
Hi, I'm using Samsung NP270E5U-K03NG so it doesn't power on, this started when my power adapter burst and the battery was off powered at the time then I got a new power adapter but still can't switch on the screen even the power led it doesn't indicate powered, please help me
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Firstly, you may try restart by plugging in while removing the battery.
While you get a new adapter, make sure it’s compatible with your device, also make sure drivers up to date.
Open the Start menu and search for "Device Manager." Under "Batteries" you should see a few items: usually one for the charger and one listed as "Microsoft ACPI Compliant Control Method Battery," though there may be others. Right-click each item and choose "Update Driver."
Once the drivers are all up to date, reboot the laptop and plug it in again. If this doesn't resolve the problem, you may want to download the latest drivers from the manufacturer's website. You can also try uninstalling "Microsoft ACPI Compliant Control Method Battery" completely and rebooting, which should prompt Windows to reinstall the driver from scratch.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
JaQuis Apryl King 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 154
