跳转到主内容
MagSafe not lighting up, and not charging
The other day I noticed my MagSafe cable is not lighting up when plugged into my Mac. The Mac is not charging I have reset the smc, and unplugged the battery. Is it the cable or could it be something else?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
do you have another charger to test? if the computer can't detect the charge it will not charge, try another charger or clean your charging port pins.
完成的
I don’t have another charger. I did clean the charging port pins also and did it help
完成的
添加一条评论
1个答案
已选择的解决方案
The first thing to do it test the mag-safe for output. On the right of this wiki is the pin out, test it with a multimeter.
https://en.wikipedia.org/wiki/MagSafe
Also see if anything is blocking full insertion on the mag-safe port (it is magnetic and can pick up small objects and block connection. Next test the pins on the mag-safe and see if they are fully extended (I use a sponger to gently press them in and see if they pop back.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Stephenw 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 100
