跳转到主内容
The De'Longhi EC155 is a Pump Espresso and Cappuccino maker.
Cleaning the boiler outlet
I can’t get the screw out to clean the boiler outlet. It seems to be welded in. Water won’t pump through. Do I have to throw the whole machine away because the screw won’t come out?
Update (01/08/2020)
Here are the pictures of the screw I can’t get out and the boiler holder (holds the coffee filter).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
jwsacco post some good pictures of what you are up against. That way we can see what you see and hopefully help you out.在已经存在的问题里加入图片
完成的
I can't get the screw out. It's stuck fast. I have tried WD40. Any advice would be appreciated.
完成的
添加一条评论
1个答案
最有帮助的答案
jwsacco it is not welded in. I think it is just hard to get a good grip on it. Use a phillips head socket and a ratchet. Place the socket into the screwhead and use a small hammer to tap the bottom of the socket thus loosening the screw a bit. The use the ratchet on the socket to remove the screw.
Check the first 45 sec off this video
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jwsacco 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 30
总计 3,002
