跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 个问题 查看全部
My replaced battery stopped charging.
hi. In my MBP, after I replaced battery it was working just fine. But after 3 months I just stopped charging. It remains at 1% even if its plugged in.
 Charge Information:
  Charge Remaining (mAh): 0
  Fully Charged: No
  Charging: No
  Full Charge Capacity (mAh): 8219
  Health Information:
  Cycle Count: 15
  Condition: Replace Now
AC Charger Information:
  Connected: Yes
Update (01/10/2020)
@danj this is with charger plugged in.
except its not poor condition. now it says good
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
A lot of after market (non-original) Li-Ion batteries are very bad quality. If possible buy from a good retailer (or eBay seller) or here at ifixit. (I do not work for ifixit).
完成的
Let's get a better view of things. Install this gem of an app CoconutBattery take a snapshot with the MagSafe charger plugged in and take a second with it disconnected after waiting 5 minutes if you can. Post both images here so we can see what's happening 在已经存在的问题里加入图片
完成的
You need to get your Battery tested with the help of a Multimeter, to single out the issue of the battery.
Please post more information on how you got this problem so that we’ll be able to help you.
Regards.
完成的
@bmx2019 I bought here on ifixit.
完成的
@danj I can't unplug the cable cuz if I unplug, the computer will shut down.
完成的
显示更多的1条评论
添加一条评论
1个答案
最有帮助的答案
Sadly, the charging logic on the main logic board has a problem. You’ll need to find someone to fix your logic board or replace it.
这个答案有帮助吗?
得分 1
1条评论:
I think it isn't charging logic because I have replaced the new battery with the original one and everything works just fine
完成的
添加一条评论
添加你的答案
martinko2k1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 95
