跳转到主内容
Released 2016, this Sharper Image stunt drone is rechargeable and has a 150-foot flying range. It is black with 4 propellers. It has a 2.4GHz transmitter. It requires no FAA registration and includes charging cable and (4)replacement blades. It has removable blade guards.
Why can't I put in the Propeller on the drone
It like I take off the propellers off because there destroyed. But when I put the new ones it won’t go on please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Propellers you trying to replace are they identical with ones you took out? If they are the same ones and doesn't go easy then you can use little wd40 it will slide in easily.
这个答案有帮助吗?
得分 0
添加一条评论
Missing spacer. The propeller sits on a spacer. The spacer connects to the rotating stem. The propeller attaches via the screw. Check your old propeller for the spacer and sore attached.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 426
