跳转到主内容
加入维修社区 - 创建账户
Eighth generation of the Honda Civic.
RPM & Check light
I’ve HONDA Civic 2006 it’s RPM suddenly starts surging up after start,temperature gauge keeps going up & down keeping me in dark about it’s temperature,check lights gets on,tried to get it fixed but invain,
I appreciate your auto-diagnosis of this issue ??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi @hbuddy ,
Did the get the OBDII port scanned for codes?
If you did what were the codes?
完成的
Need more information: Did both problems start happening at the same time? Did they all of a sudden show up, or did it start to happen more often over time? Does it do it ALL the time, or just when starting cold?
完成的
添加一条评论
1个答案
its probably going to be an issue related to your coolant system which is probably making the engine rpm’s increase in order to try and make everything else work harder to cool the engine back down. check thermostat, double check for any leaks, and try and get the relay for the fan checked. hopefully it’ll be one of those.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
SHEHZAD Akhtar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 161
