跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
LCD dead after housing replacement!
I just replaced my back housing but now the LCD and digitizer won't work! The phone is on because music plays from the headphones.
Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
tried a reset? press and hold power and home for 10 seconds..apple should appear, then allow to reboot.
完成的
I checked all the cables! Played around with them for like 30 mins but nothing. :( Any other ideas?
完成的
添加一条评论
3个答案
已选择的解决方案
Try cleaning connectors 1&2. Check the pins for any damage. Then if still no effect you could try taking board out for 20 minutes or so (seems to rest the board in some cases.. Had this happen with one of mine when LCD wouldn't work) if that doesn't work try restore in iTunes(backup first!) if that doesn't work try new screen
这个答案有帮助吗?
得分 2
添加一条评论
Check your ribbon wires on your iphone to see if any of them broke or unplugged during your installation
这个答案有帮助吗?
得分 1
1条评论:
There is a teardown spot for iphones here on this site you can go by to check and see if any cables are disconnected
完成的
添加一条评论
check the lcd socket maybe it will not fit well...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jeremy Scalpello 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 767
