跳转到主内容
型号 A1238 / 80, 120, 或 160 GB 硬盘 / 黑色或银色面板
1019 个问题 查看全部
iPod is dead , but when I connect to power, it reboots every 2 seconds
I have a 120gb iPod classic and I’ve known the battery hasn’t been great for a long time now. About 8 months ago, I was only able to listen to it connected to power and once disconnected it would die in 5-10 minutes.
Now I can’t even get the iPod to power on to the menu regardless of a power source. It’s rebooting extremely quickly (the Apple screen is flashing every 2 seconds nearly) and from all the troubleshooting pages I’ve found on the internet, I haven’t had any luck thus far. When I hold the Menu+Center buttons, the iPod will momentarily respond by keeping the Apple screen displayed until it begins restarting once more in a few seconds as I continue to hold the Menu+Center buttons. I have also tried to put it in disk mode by doing the above, and as the screen begins to reboot, pressing the Back+Forward buttons down simultaneously. This has yet to make the iPod respond any differently as it continues its rapid reboot cycle.
Any help here is greatly appreciated. I have a lot of old music I won’t be able to find anywhere on this thing.
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
最有帮助的答案
Unfortunately I think replacing the battery is the only option in your case. It is a relatively difficult process to replace it, but it is possible.
Here’s a link to the one on the ifixit store: iPod Classic (Thin) Battery
iPod Classic (Thin) Battery图片
产品
$13.99
这个答案有帮助吗?
得分 1
评论:
You think it's the battery then? Even connected to a power source, a dead battery would prevent the iPod from booting to the menu? That seems odd.
完成的
I guess I'm just confused as to why it would work with a failing battery 8 months ago and now with the same problem I can't get it out of the infinite reboot or even to really respond to anything I do.
完成的
Sorry for not writing back sooner. For some reason this is an issue when the battery starts to fail. I'm not sure exactly what the reason is, but many people have fixed this issue by replacing the battery.
完成的
添加一条评论
Had this same. You need to replace the battery.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sean 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 28
