跳转到主内容
A smaller version of GM's rebirth of the Hummer.
22 个问题 查看全部
Park lights won’t turn off
Park lights stay on after vehicle is turned off
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@harv177 common issue on the H3 is a short in the trailer wiring touching the chassis and causing issues. Open the tailgate and carefully inspect the wiring harness. Pull the Trailer B+ fuse and see if that turns the lights off. If it does you know it is a short in that wiring. If it does not, check the light switch with a multimeter.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Harvey 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 17
总计 539
