跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
Won't boot if I/O ribbon cable is plugged; replaced cable, same error
After a whole lot of due diligence, I diagnosed that it was the I/O flex ribbon cable causing my MBP (13” retina early 2015) from booting (couldn’t even get the apple logo, only the sound and a brightness adjustment on the black screen). However, if I unplugged that i/o ribbon cable, it booted and worked fine, albeit no wifi/usb/bluetooth.
So I bought a new I/O ribbon cable from iFixit, replaced it, and everything worked just fine until the laptop’s first full charge. Now suddenly it won’t turn on again unless I unplug the ribbon cable!
Super weird and super bummer because I was very excited to have it working smoothly again. Could this be an issue with the I/O board itself? Or something else?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sounds like your I/O board has a problem too! MacBook Pro 13" Retina (Early 2015) Right I/O Board
Often I find a liquid spill damages both.
MacBook Pro 13" Retina (Early 2015) Right I/O Board图片
产品
$9.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jordan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 6
总计 289
