跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
678 个问题 查看全部
Is my logic board dead? Saw small flame on iPhone 8 cam ribbon.
I forgot to unhook the battery. Self teaching repairs. IPhone 8 front can ribbon flamed up a bit and the screen had worked prior. Did I damage the logic board, battery or screen… or all 3? Won’t turn on at all now. Suggestions for a device to test screens? Device to test separated logic boards? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Thank you. Any suggestions on a reputable micro soldering company would be appreciated.
完成的
@nameistrey You should give your approximate position so that someone may possibly give some suggestions.
完成的
I’m located in Austin, TX
完成的
添加一条评论
1个回答
已选择的解决方案
Sparks and smoke point to a short to ground and burnt components. Try unplugging both cameras connectors, disconnect and reconnect battery and see it the phone starts without those parts in place. In case it doesn’t the logic board sustained damage and needs to be fixed at microsoldering level. If it boots, plug back the rear camera, replace the front camera assembly and reassess damage. There’s not much else one can do beside replacing parts on an iPhone without professional tools and skills.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
S. T. Wood 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 32
