跳转到主内容
An economy SUV by Mazda, not the greatest sport utility vehicle in the world, just a Tribute. Made in the USA by Ford Motor Company. Simply a rebadged Ford Escape.
Sputtering Engine & Bad brakes out of nowhere!
2003 MPV started sputtering really bad and brakes easy then hard to press. Both occurred at the same time and overnight.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @bookwormdmc ,
Check if the brake booster is working OK.
Here’s how to do this
With the engine off, pump the brakes — about five or six times is sufficient. This depletes the stored vacuum.
Turn the engine on while pushing down lightly on the brake pedal. If your brake booster is working normally, the pedal will fall away a little, but then become firm.
If your brake booster is not working correctly, nothing will happen, or the brake pedal will push back against your foot once the engine starts. This could be a sign of a brake booster problem or an issue with the vacuum hose.
A faulty or loose vacuum hose could also affect the engine.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
D. Milam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 516
