跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
253 个问题 查看全部
Will a screen replacement fix flexgate?
Hey, I'm a apple customer from India. I'd bought my MBP 2016 15 inch in late 2017 and have just detected the beginning of flexgate today, the 26th of December 2019(The spotlights have appeared). What I need to know is whether a screen replacement is a permanent fix for the same . That is, does the official screen replacement have a longer cable? Or is it still prone to flexgate after a year or two of usage?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Apple is replacing the full display assembly with a newer version which does have a longer backlight cable.
Depending on supplier an independent shop may not have the newer part.
这个答案有帮助吗?
得分 2
5条评论:
Do you have a part # on the newer display yet?
完成的
Thanks so much, really appreciate it
完成的
@mayer
The newest version P/N's
661-08030 - Space Grey
661-08031 - Silver
完成的
Does the replacement also include 15-inch MBPs?
完成的
@LEON PATRICK MAWLONG - Apple does not have an official program for the 15" models. But! Don't give up! You'll need to visit a real Apple Store and make your case for a warranty exception. You will need to be able to show them you haven't damaged your system in any way and the movement of the screen cuts the backlight on and off or gets stage light effect.
完成的
添加一条评论
添加你的答案
Jason Sequeira 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 11
总计 1,348
