跳转到主内容
加入维修社区 - 创建账户
这是由索尼电脑娱乐(现已重组为索尼互动娱乐)生产的游戏主机。PlayStation 4 Slim(CUH-2000系列)是比初版PS4更薄的替代型号,于2016年9月7日正式对外公布。
PS4 doesn't accept discs
My PS4 Slim doesn’t accept any discs I put in it. It doesn’t even try to suck it in and doesn’t read it when I manually put it in. I checked all the ribbon cables in the back, they’re all fine. When I push the eject button, it makes the sound that indicates that there is no disc in the optical drive. Any ideas on what might be the problem? I already tried a lot to make it work. Should I just buy a new optical drive?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
As these drives are not really repairable, you would be better off replacing the Blu-Ray drive rather than reparing it.
you can buy a replacement on eBay or new-egg
这个答案有帮助吗?
得分 1
添加一条评论
I just had a similar issue on a PS4 Slim, turned out to be dirt jamming up the grooves in the disc roller gears, it was causing the rollers to be sluggish and skip a little but ultimately didn’t have the torque to fully pull the disc in or eject it once forced in, this would also prevent the disc from settling all the way in so that the drive could properly read it. Once I cleaned out the gear connected to the rollers and carefully used a small jewelers flathead screwdriver and a nylon brush to clean the other two gears it works like new. Hope this helps others with this issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Charlie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 306
