跳转到主内容
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
179 个问题 查看全部
2003 Dodge caravan fuel gauge
fuel gauge 1/2 tank but runs out of gas
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
This sounds like a sender problem, you can replace the fuel pump that has the sender for fuel level integrated — another potential fix is to put in a couple bottles of fuel system cleaner on a half tank or under of gas. Often it will free the sender. But to replace everything you have to drop the tank. We had a Caravan with similar problem and just tracked miles very carefully.
这个答案有帮助吗?
得分 0
3条评论:
How do u know if everything has to be replaced
完成的
No i always keep it full actually it's just a 1/4 used only go to work and surrounding area.
完成的
@Balerie Stokes if the fuel sending u it goes you have no choice. It all comes together as one unit. Fuel pump, sending unit, etc. They're typically one piece so if one goes, you have to replace the entire unit.
完成的
添加一条评论
Suspect either a faulty gauge or sending unit in tank . Either way start by checking the wires on the fuel tank sending unit which also powers the fuel pump. Your looking for loose and or corroded connections.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Steve Wolfe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 389
