跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
After Replacing Battery, Battery Won't Charge
I just replaced my Iphone 3gs battery. I put the phone back together the battery was read, and it was at 45%. I plugged it into charge and the battery would not take a charge. The battery is now dead and everytime I plug it in it will start up then immediately power off. Itunes reads the iphone I manged to put it into restore mode, and restore it while dead but that did nothing. It's now restored but the battery still won't charge. I took it all back apart to ensure everything was connected properly and it still won't charge. I was reading on here about a battery charging fuse and was curious. Though when my phone was on the vibrate function did work. The phone charged before i replaced the battery. And yes I tried the simple stuff such as using a number of different chargers and still nothing. Please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Let me be the one to say THANK YOU. It was my own stupidity and impatience that prevented me from trying to put in the old battery. I just put in the old battery and it charges fine, and dandy. So your experience is correct, and I can now add it to my experience the battery is faulty. Thanks again.
完成的
No worries! You were the one to think of putting your old battery back in so don't go giving me all the credit :P
完成的
添加一条评论
1个答案
已选择的解决方案
3G/S Batteries have a history of being very faulty (personal experience). My best bet is that if your iPhone was charging beforehand then the dock connector is fine, you will just need to order another battery. Contact your supplier, inform them of the situation and ask for a replacement. 9 times out of 10 they will send you one for free as compensation :)
hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Justin Thessen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 4,338
