跳转到主内容
The Ford Fiesta is a subcompact car (B-segment in Europe) manufactured by the Ford Motor Company since 1976.
23 个问题 查看全部
How to correct dtc P0017?
Replaced failed water pump and afterwards got P0017 which is camshaft/crankshaft position correlation bank 1 sensor B that pertains to timing probably one tooth off on timing belt. I was needing help/advice to correct this problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
if the code is still up then get a mechanic to read the freeze frame data and they should be able to determine where the issue is, it may be your timing itself but it can also be faulty cam/crank sensors, faulty or damaged wiring, solenoid/actuator, tone ring broken or slipped, it relates to the exhaust cam and crank rather than intake side. if its the teeth or stretched belt/chain it will be over 10 degrees out at idle, check to see if its a chain or belt depending on the engine and what the mileage is for changing them. a good garage should be able to pinpoint the issue without just jumping straight for a new timing set, may save you a few hundred.
这个答案有帮助吗?
得分 0
1条评论:
sim é util, por favor quero consertar meu veiculo que é velho e so tenho ele para me locomover
完成的
添加一条评论
添加你的答案
t41m4dg3 k3mp 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 97
总计 5,893
