跳转到主内容
This Sony 60-inch television produces natural color and outstanding brightness due to 3LCD technology. The Sony WEGA Engine used in this Sony projection television gives you complete picture clarity from any compatible video source by minimizing the digital-to-analog conversion process.
8 个问题 查看全部
Why is my Sony Barvia 60" the flashing red 6 times constantly
How can I fix my tv I've tried to unpack.ug it but it's on a wall I've tried to tune it on and for like 1 milisecond it turned to just Sony the no picture blank screen and constantly flashing red 6 times I just need it fix asap thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Deanna Warr we need to know your exact model. For the Sony Bravia a 6 blink error code is usually related to a backlight issue. This can originate from the main board, or the power supply as well as other issues like a failed backlight array. You will need to remove the back cover from your TV and check the boards for obvious damaged components. Check the voltages going from the power supply to the main board as well as to the LED connectors. Post some good pictures of your boards etc. so that we can see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Deanna Warr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 106
