My speedometer isn't working what reasons is there
2005 Nissan maximum speed ahman or was on and off working for about a month now it's totally not working what is the fix and can something be cleaned order to get replaced
could either be a faulty gear in the speedometer system, speed sensor may be faulty or an ECU issue, try the sensor first and see if you have any luck then see if you can get anyone to fix or fit a new instrument cluster. hopefully its one of those 2.
这个答案有帮助吗?
Have you recently had any work done with the stereo or the AC unit that requires the center of the dash to be removed? There is a computer behind this section that, when it is removed, can affect the Tachometer from working. When I was fixing this issue myself, I was told that there are occasions where a coin or a random metal item can fall into the vent cracks of the module and short it out. That module behind the dash could be the problem.
这个答案有帮助吗?
Disassemble your instrument panel and freshen all the solders on the back of the panel. It will work.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 688
