Red light keeps blinking when I try to take off
Phoenix gps foldable video drone
Hi,
Does it successfully take off?
According to p.15 of the user manual (if this is your model?):
“The red LED will flash if there is no memory card inserted or if the memory card is full”
这个答案有帮助吗?
That is not true I have a brand new memory card and the light still flashes red and I even tried taking it out and it still flashes red
I was having the se problem, dude that said it's the sd memory card is 100%✓ correct. Dude that said "not true' .. "idiot, gosh," as soon as I entered the sd card the drone like came alive. Flew it like half a mile excellent machine.
这个答案有帮助吗?
SD card was not the issue with mine, after almost a year of not being able to figure it out, I just tore the thing apart, and used the parts on a home-built drone, and it works fine now LOL
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 19
总计 2,315
4条评论
how do you fix it?because my drone do the same thing
由 Amar Alexander 完成的
Same issue here as well, I was able to fly it for about 3 minutes, then the drone 'returned to home' - The red light on the body was blinking repeatedly, and the controller was beeping - Drone is brand new, never crashed - If anyone has any idea what the issue could be PLEASE reply here!
由 Jason Olson 完成的
how do you locate a dead drone
由 Justin Mudd 完成的
No this is the pheonix foldable drone. Most likely you have a GPS module issue. I have several with this issue. Did you ever figure it out? If it is the same one it has a series of red blinking lights. 4 blinking lights in a row, pause 1.5 seconds and repeat is the GPS module.
由 Cedric 完成的
