跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Repair and disassembly guides for smartwatches designed by Apple.
520 个问题 查看全部
Apple watch series 5 force touch sensor
Hi, I have just replaced the glass on my apple watch series 5, but I have to replace the force touch sensor, as it got a bit mangled in the process.
The series 4 is similar to series 5. Do they share the same force touch sensor?
Because I seem to only find replacements for series 4 and below.
Also does anyone know what is the right driver for the screw holding the force touch connector in place? That would be very helpful.
Thanks,
Rafal
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Sorry, I just don’t know as I haven’t tried working on this series yet.
Let’s see if the iFixit folks know Apple Watch parts compatibility
完成的
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
1个回答
最有帮助的答案
Hi Rafal.
Unfortunately, the connectors of the Series 4 and Series 5 Force Touch Sensors are different (connector pins and length), so they are not compatible.
The driver for the plate screw would be a Tripoint #000.
这个答案有帮助吗?
得分 2
评论:
Do we know we’re to get the force to inch sensor at
完成的
添加一条评论
添加你的答案
Rafal112 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 11
总计 93
