跳转到主内容
MacBook Pro sleep indicator light does not turn on when sleeping
I have a 2010 Macbook Pro and when I put it to sleep, either via the Apple menu or by closing the lid, the sleep light indicator does not turn on at all. I’ve performed an SMC reset and PRAM and have realized this is not the issue.
Here’s what I found: Last night while moving my notebook with my right hand the sleep indicator light turned on then off when I let it go. After pressing again under the case, I noticed the light would come on then off when releasing pressure.
My guess was it might be the hard drive ribbon cable. I installed an SSD except that was about 4 months ago and the sleep light indicator had been working fine. So I removed the bottom case, checked the ribbon cable and it looks to be intact.
Might it be the ribbon?
After screwing the bottom case back on and trying again, the sleep indicator light still does not turn on. I noticed that if I press the area near ( where the brackets screw in to hold the drive) under the case, the light turns on and off after releasing the pressure.
My other questions are: The SSD I installed is not as thick as the old HDD, would this cause the ribbon to loosen, so that it is not pressed or taut/snug from the inside, or is it a faulty ribbon? Is there a way to test the ribbon?
Help is much appreciated, thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Change the hard drive cable to the 2012 model as it is built for using SSDs.
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable图片
产品
$34.99
这个答案有帮助吗?
得分 2
2条评论:
Thank you Mayer, I'll give it a shot and report back as soon as I get it installed. Might be a while as I didn't expect another expense this month. Nonetheless, thanks again.
完成的
Mayer, I'm back with an update. I purchased the 2012 drive cable you suggested and it did not fit. The ribbon fell short about half to the pin connector on the mother board. I should have measured it against the original ribbon prior to installation but was certain it would fit.
I purchased this without the bracket and the installation was going well, until I got the pin connector to the main board and it didn't reach. I was able to uninstall it and reinstall my previous cable and will have to look around for another solution.
Here's an image showing the two ribbons: https://www.dropbox.com/s/wmtirmugp1e34h...
Unfortunately this wasn't purchased through iFixit in an attempt to save money, and cannot return it. I will also have to see why my battery isn't reading correctly now as well. Not sure what happened there but it says my battery isn't charging.
At any rate, thanks for your possible solution but that 2012 hdd cable doesn't fit the 2010 model.
完成的
添加一条评论
添加你的答案
zerimar3 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 397
