跳转到主内容
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
969 个问题 查看全部
Screen started doing this, now won't turn back on
Toshiba Satellite L850
I've had the laptop for about 7 years probably, and it's been running pretty well until this happened today.
The screen had some letters all over it and then turned off and showed this a few times and then I force shut it down.
Is this fixable or is it the end?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
First thing I would try is connecting it to an external monitor. If the screen on the external monitor works fine, then it could be the cable has came loose or need a new screen. If the external monitor also does the same then it could be something such as a bad driver or bad video card.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Haley L 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 24
