跳转到主内容
加入维修社区 - 创建账户
苹果 AirPods 是于2016年12月发布的无线耳机。
My Right Airpod is quieter than left.
Hi, about a week ago I started to notice that my right airpod is quieter than the left one. I thought ear wax was the problem so I bought alcohol and carefully cleaned them, and after that carefully sucked the holes. I had no improvement at all. But what I noticed is that when I try to suck left airpod from the center grill I have less airflow than with the right one. What can I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
I know this is old, but something weird just happened, and your comment made it happen. You said “when I try to suck left airpod from the center grill I have less airflow.”
Okay. My left AirPod has been lower than my right one for a week and I couldn’t fix it. After reading that comment, I put my mouth on the speaker part of the AirPod and softly sucked in and out a couple times, and the volumes are equal again. What just happened?
完成的
添加一条评论
5个答案
已选择的解决方案
Sounds like the speakers diaphragm has a tear. Did you get AppleCare+ for them?
Sadly, there is no real way to repair them (Apple designed them as throw-away)
这个答案有帮助吗?
得分 2
3条评论:
No, I got them for my birthday last month, can I just go to apple store and get only the right airpod?
完成的
@acimiccc - You'll need the original receipt to prove the purchase date. Bring both AirPods and the case. I wouldn't admit you tried cleaning ;-}
Good Luck!
完成的
@danj Yea, Thanks for the tip! :)
完成的
添加一条评论
This has happened to me like 10 times till this point usually alternating airpods what you can do is walk into apple and as long as your still under warranty and they havent been heavily cosmetically damaged you’ll get them replaced.
这个答案有帮助吗?
得分 1
添加一条评论
If you have expensive AirPods, I would give them to a specialist to solve this problem. If not, I would buy new ones. This is why I buy inexpensive devices because I know that they often break down. After I broke an expensive phone without being able to fix it, I decided that I won't spend a lot of money on devices. And I can say that I bought fake AirPods (here you can see the review https://woahtech.com/best-fake-airpods/) and am pleased with their price and quality. So I use them mainly to listen to music on the bus/train or when I run in the morning. Due to the fact that they have excellent noise insulation, my brain is resting from the noise and bustle of the city. I turn on Chopin music and run along the ocean coast, it creates a sense of comfort and relaxation.
这个答案有帮助吗?
得分 0
添加一条评论
these are not good answers.
这个答案有帮助吗?
得分 0
添加一条评论
I know the thread is old.
Over the summer, I had a pair of AP2 and I took them back from my daughter because she upgraded to AP Pros. One day I started using them and one earbud was muffled and the sound was low. I thought that was odd because there is no visual damage of it. It still charges and holds a charge. I tried all of the tricks including cleaning, adjusting the sound, etc.... and nothing seemed to fix it.
A month or two ago, I took them to Apple and the guy ran a diagnostic test and told me there is something wrong with both earbuds. He didn't go into detail of the problem but the case is fine.
The conclusion was I had to replace them with new ones. I still don't know what happen to them. My daughter could have dropped them for all I know.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aldin Cimic 将永远感激不已
浏览统计数据:
过去 24 小时: 40
过去 7 天: 160
过去 30 天: 714
总计 31,283
