MacBook Air unexpected shutdown with battery
Hello!
I have a MacBook Air 13 (Early 2014) with liquid damage with motherboard 820-3437-b.
When I plug it to MagSafe and detach battery it works great. But with battery often shutdowns unexpectedly (as full power outage), whether power is connected or not.
I have replaced SMC controller with cable, battery. I tried to reset SMC and NVRAM.
Today I received refurbished motherboard for my MacBook and tried to test with it, but it didn’t help.
Please help with this problem.
Thank you.
Coconut information:
4条评论
Install this gem of an App CoconutBattery It will allow you to monitor your battery and its charging. How about taking a snapshot of the apps window and post it here so we can see what's happening 在已经存在的问题里加入图片
由 Dan 完成的
Added. I think that there is incorrect information. I bought this battery in February 2019. It is impossible to charge 8k times.
由 Akbarkhon Amirkhonov 完成的
WOW! 8,426 cycles! Clearly the batteries logic is bad!
Within the battery is a small microprocessor to manage the batteries charging as well as take note of the number of cycles it has gone through.
You will need to replace the battery to move forward.
When you took this snapshot was the MagSafe charger connected? If it was you still have a logic board issue, likely you have damaged charging MOSFET's here.
由 Dan 完成的
MagSafe was disconnected. Thank. I'll try to change a battery.
