跳转到主内容
三星公司于2018年3月发布的旗舰手机,盖乐世 S9。
137 个问题 查看全部
Would I need to replace the LCD or the LCD with digitizer?
I have an s9 and I've dropped my phone which crashed. I tried turning on my phone and it only show the top half and the bottom half green screen flickering. I'm not sure which part of the phone I should get fix and I have little to no knowledge about this.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Samsung Displays are the more high tech on the market, OLED Display ,TouchScreen and Front glass come from factory in sandwich mode less than 2mm, replacing single parts such as OLED or Touch Screen requires expensive equipment, and in your case you have a bad OLED Display (The Expensive Part), so you have to replace the complete Screen sandwich.
SUMMARY: Replace OLED Screen Assembly, is DIY Project, Replace OLED Screen Assmebly with Frame/Housing.
这个答案有帮助吗?
得分 0
1条评论:
Yes, thank you and i know its really expensive part. I broke it recently and wasn't sure which part to get it fixed which I asked phone repair shop and they say around $260 and up.
完成的
添加一条评论
The LCD and the digitizer are basically fused together. You will need to replace both. If you are doing it yourself then good luck, the screen is glued on tight.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kelly tran 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 576
