跳转到主内容
Model A1990 / EMC 3359. Released in May 2019 with new 6-core and 8-core processor options.
87 个问题 查看全部
My MacBook Pro 2019 glitches when shutting down
My macbook today do this glitches line on the top of the screen when i shutting down, i tried to shutting down many times and it all the same. The screen totally working fine when i'm using it but only does this when i shut down.
I found some post about " Automatic Graphic Switching " option can cause this kind of glitches, i turn it off and everything was fine now, anyone know if this software or hardware problem?
I'm running Catalina on MBP 15 2019.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Technically, its a hardware issue. All you did is hide it turning off Automatic Graphic Switching.
I’ve seen this a few times now. Now the rub as it can be hidden Apple will likely not fix your system. I sent three people to Apple only one got a replacement system as it was still within the first 30 days. He also needed to check three systems to get a properly working system. He was smart as he spent the full day at the store! Setting up each the new system there. The other two failed to get the genius to take the system in for repair.
Apple is having a big issue in quality control this year which appears to be coming to a head. The genius’s are doing their best to deny taking in repairs on what they believe are minor issues or deep issues which are hard to isolate.
这个答案有帮助吗?
得分 2
2条评论:
do you know why it's only happen when i'm on Adapter Charger ? It's fine when i'm on battery, no glitches.
完成的
Sorry, only Apple can answer that.
完成的
添加一条评论
添加你的答案
Huang Pak 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 3,874
