跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
253 个问题 查看全部
Why does my MacBook 15 inch 2016 keep restarting?
My macbook keeps restarting randomly, sometimes when it’s asleep. It stopped working recently and had to have the motherboard replaced but it still keeps restarting. I have tried everything including a full wipe and reset. It stopped restarting for awhile but now it’s doing it again.
Here’s what the report says:
panic(cpu 0 caller 0xffffff7f8e54e970): "UPSB(MacBookPro13,3): thunderbolt power on failed 0xffffffff\n"@/BuildRoot/Library/Caches/com.apple.xbs/Sources/IOPCIFamily/IOPCIFamily-370.0.2/IOPCIBridge.cpp:1396
Backtrace (CPU 0), Frame : Return Address
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Sadly, your logic board either still has a problem, or one of your Thunderbolt port assemblies has a short.
Carefully disconnect the thunderbolt port assembly one side at a time (using the working side for your power)
You also may want to double check your power adapter is it an Apple unit of other? Are you using the original Apple USB-C cord? Not all USB chargers are the same! And the cords are likewise not all the same!
Some 3rd party chargers use different signals to monitor their charge rate and the cords wire gage on the power feeds may not be heavy enough to carry the higher current.
The last variable is the AC power its self! Make sure you are using a properly grounded outlet and ideally a surge suppressor (I have a nice two port unit for travel) or better yet a UPS while at home.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sebastian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 967
