跳转到主内容
The Dell 1710n is an office laser printer released in 2011.
8 个问题 查看全部
How to remove white 'scuff'marks on print jobs?
Had no problem until this week - my 1710 printer is not printing clearly, there are scuff marks that repeat in 'white cloud' shapes down the page in regular intervals. I have pulled out the printer catridge etc and have wiped out excess toner internally via the front panel. Is this problem caused by a piece of paper stuck on the rollers ?? The dell toner cartridge is hardly used, as new.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This is usually caused by a scratched drum. If not, then you exposed it to too much light or you exposed it to light or touched it.
Usually light damage is permanent. You probably need a drum at that point. However, if you let it sit in the printer and not use it, it may recover. It probably won't, but it does have a chance. It's better then assuming a drum dead and that's like 50-60.00 to replace dead. Scratches are always cases a drum rebuild or a new drum is required.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Johanna 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,120
