跳转到主内容
The Samsung Galaxy Tab S 10.5 released in July 2014 is a 10.5” Android tablet with a 2560x1600 pixel resolution, 16GB of storage, and 8.0MP camera. Model numbers: SM-T800 (WIFI), SM-T805 (Cellular and WIFI)
100 个问题 查看全部
My on-screen keyboard has stopped working, and I cannot login without
My Samsung tablet, which i have had for years has recently started not working. First off my tablet requires a manually written password to login after a restart, and the on-screen keyboard does not work anymore. This makes me unable to do practically anything.
Furthermore a weird sort of Blackscreen has started appearing right after a restart and lasts for around 2 minutes.
Appreciate any help!
It says SM-T805 on the back, if that is of importance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @macmo ,
Couple of things to try:
Clear the device’s cache partition and check if this resolves the problem. Here’s a link that shows how to do it.
DO NOT select wipe data/factory reset as this will erase all your data and downloaded apps and restore the tablet to its’ factory default condition
Try starting the tablet in safe mode to check if it works OK.
If it does then a downloaded app is the cause of the problem.
The trick is to find out which one.
You will need to uninstall each downloaded app, one by one and restart the tablet between each uninstall in normal mode to see if the problem is still there or not.
Once it starts up OK then the last downloaded app that was uninstalled was the culprit.
这个答案有帮助吗?
得分 3
1条评论:
Clearing the cache fixed it!!! Thanks good sir
完成的
添加一条评论
添加你的答案
Macmo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 41
总计 2,079
