跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
247 个问题 查看全部
Screen color distortion, flickers
Hi everyone!
I’ve got a problem with my book:
Display doesn’t work fine — screen is flickering a little bit, colors are distorted. Sometimes there’s even blackscreen.
However, there is important note that it works fine only if macbook is open fully or is open at approximately 45 degrees.
Screens:
https://drive.google.com/open?id=1POYzqw...
PRAM reset didn’t help, btw.
Also I can’t change it bcs it’s 15’ and it is not a screenstage.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Sadly your display cables have become damaged! This is a similar problem we saw with the FlexGate issue which was a different ribbon cable in its case it was a bit short so it got stressed. In this case you likely banged the clutch cover just at the right place to kink the cable so over time it fatigued.
Here’s a view of the cables
You’ll need a new display assembly MacBook Pro 15" Retina (Late 2016-2017) Display Assembly and here’s the guide 2016 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换
MacBook Pro 15" Retina (Late 2016-2017) Display Assembly图片
产品
$549.99
这个答案有帮助吗?
得分 2
4条评论:
Hi,
can I change the flex cables without buying a whole new display?
完成的
Sorry no ;-{
The cables go directly to the LCD panel you need very special equipment to bond the cables on .The lid is also glued together and so taking it apart would be close to impossible without breaking it. And lastly, were are you going to go to get the cables? They are not available either.
完成的
Ah, that sucks!
I read about changing the LVDS flex cable which is available for ~10€ on eBay and my hope was that this would fix my issue. Or at least I try this before investing hundres of euros.
But I guess I'll watch some display replacement videos to see if I'm capable of repairing it myself.
完成的
@larrygrabb - The new Touch Bar systems are the least repairable MacBook Pro's yet! Its all most a 2~3K throwaway system ;-{
I'm sure the coming Apple Silicon systems will be!
完成的
添加一条评论
添加你的答案
alexander 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 2,141
